RCU Forums - View Single Post - Pull Pull Rudder
Old 06-17-2008 | 12:00 AM
freeair
Default RE: Pull Pull Rudder
just keep both the wires in line as theres no need to cross over, make sure when you fit these wires its a smart idea to use either some small brass tubeing or plastic tube to where these wires exit the fuseage, if you dont eventually the wire will cut into the fuselage balsa causing slack in the wire . the wire i use is fishing trace nylon coated, cheap and very strong.
