mip 4-n-1 clutch help
Make sure the pins are not sticking out in the back of your flywheel they will rub on the engine case and wear a hole in it also the weights are for fine tuning the clutch if you put in the weights your clutch will engage at a lower RPM and without the weights it will engage at a higher RPM
