RCU Forums - View Single Post - Hangar 9 Twist 3D Part II - Thread Continuation
Old 06-17-2008 | 08:13 AM
  #3754
Waldopepperaxel's Avatar
Waldopepperaxel
Default RE: Hangar 9 Twist 3D Part II - Thread Continuation
Kerwin I noticed sometimes with the T_ _ _ T she won't go into a flat spin because of too much throw, with 5 as the CG I woiuld think you should have no problem, I used to throw the controls to the extreme and she would flat spin in a heart beat, but I think making all my control surfaces pretty much 90 degree throws is a little counter productive, Anyway I climb straight up and then start my spin with ailerons and slowly add the elevator and then counter rudder and she spins just fine but If I start with elevator and aileron or rudder then add the oposite of either she just does this crazy looking death flipping flopping sort of spin. its weird sometimes but it works just fine, I still can't climb in the flat spin either. motor is probably just too heavy, or there is too much glue in my plane. Actually I did replace most of the broken parts with new wood so there isn't really and excess of glue wood in there, hell it almost looks brand new. I don't know,, I'm ramblin now...
Gputt great to hear from you, Were looking for a new house also so I know what your going through, glad you got out there though, Sounds like a bad servo to me Sometimes I take them apart and re solder the connections to see If I can get it to work again, but for $8.00 - $15.00 I just strip them down for plastic parts and buy a new one these days, its just not worth losing a plane to me.
