RCU Forums - View Single Post - CG QUESTION ON WILDHARE YAK
Old 06-17-2008 | 08:43 AM
rctom's Avatar
rctom
Default RE: CG QUESTION ON WILDHARE YAK
The reason is it's easy to pick the plane up at the wing tips with the help of an assistant. You can balance the plane anywhere on a line between the wing tip balance points, it doesn't have to be at the tips.
TF
