RCU Forums - View Single Post - YA P40E (What is your plane's weight??)
Old 06-17-2008 | 10:06 AM
ardrhi
Default YA P40E (What is your plane's weight??)
Morning Everyone,
I have purchased this kit, and intend on bashing it a little. I have built warbirds several times prior. However my goal, (Being as I enjoy building even more than flying.) is to dig in, and build my first finely detailed scale model. So, with that in mind, I realize that weight will become a major issue. I am aware that models built this way, generally tend to be on the heavier side. That said, how heavy is too heavy? Please give me your input. I would love any answers or input you have on the following questions. Or any others I _haven't_ listed. [8D] In this area, I can see where wing loading could VERY quickly get out of control. [X(]
1- What is your airplane's weight?
2- What is the wing's approximate percentage of the overall aircraft's gross weight?
3- What engine are you using?
4- What are your plane's flight characteristics?
5- What did you use for glassing? (Poly, Epoxy, Vinyl, Polyester?)
6- What is your opinion on a target for maximum allowable weight, without serious detrimental flight characteristics. (For a scale aircraft with the above listed agenda.)
Thank you all,
Chris
