RE: Miller RC "Persuader" giant scale starter
Remove the strip switch from the sullivan dynatron and mount it to the miller handle with nylon tie wraps on the ends. You can remove the plastic switch holder from the front of starter to clean things up. I have built three this way and they all work well with one hand. Run the switch wires to the back of the starter motor using the original strip switch holder slot on the rear motor cover.
