RCU Forums - View Single Post - engine won't run at high RPM
Old 05-11-2003 | 02:58 AM
chrisc
Default engine won't run at high RPM
I have swapped the engines on two planes and the other engine ran fine on this plane but my 40LA still exhibits the same problems on the other plane. This leads me to believe it is definitely a problem with this engine. Thanks for the advice. I will try pumping fuel through the needle valve and checking for vacuum leak at base of carb or plugged spray bar.
