RCU Forums - View Single Post - engine won't run at high RPM
Old 05-11-2003 | 03:16 AM
chrisc
Default problem solved
I like to do one thing at a time so I went to the garage and pumped fuel through the needle valve both with the valve in and with it removed. I hooked everything back up set the needle valve and tried it. It works fine now. Thanks for your quick response.
ChrisC
