RCU Forums - View Single Post - Troubelmaker
Thread: Troubelmaker
Old 06-17-2008 | 07:28 PM
bipeflr
My Feedback: (8)
Default RE: Troubelmaker
I have tried to post pictures of my Troublemaker but havent been able to. I Emailed one to a friend and he said he would post it. I am having almost as much trouble flying it. After installing the elev. servo above the stab I also had to add 2oz. of lead with it.The O.S. is heavy. For a small airplane it weighs 8lbs. OUTCH. The plane was built in the late 70s with epoxy and the rhom air retracts are originals,I have had gear failure on every attempted flight.but after replacing almost everything I think I have them fixed. I should have done that first but each time I tested them at home they worked great. After all this the plane is a great flier fast and grooves and even with its weight it will still land nose high without trying to stall.I hope the picture shows up soon because it looks great and even with the weight it flies as good as it looks. When I try to post picture it pops up they are not supported and I havent a clue whats wrong. I will try flying with all gear up soon. Jim
