ORIGINAL: CGRetired
-cut-
If you have not done so already, REMOVE THE PROP. Slowly move the throttle to full. It should beep. Slowly pull it back to idle. It should beep again.. maybe two or three times. The next movement of the throttle should start the motor turning.
-cut-
CGr.
Misslemans last post applies here too.
My ESC is armed as soon as it is plugged in.
Rob
