ORIGINAL: soarrich
Doesn't the 3W snorkel give the best reading of the pressure at the carb opening, whether it's pointed forwards or backwards?
Not realy. When the pressure under the cowl changes, the rise/fall in pressure has less influence on fuel flow, than on amount of air (by weight) entering the engine, and mixture strength will be disturbed.
Look at it this way: If you take your engine into high altitudes, you have to lean the needles, even though carb mouth and membrane pressure change equally.
BTW,
I test flew the plane this afternoon through the whole speed range using a 23x10 prop. The 24lbs Cub now has unlimited vertical. Normal on the wing flight is at about 1/4 throttle.
There was one full speed lean hickup, so the main needle needed opening a wee bit (~8 minutes), and that was all. Opening the main did not cause static rpm to drop, so I guess I was slightly lean on the high needle to begin with.
Even with the static tube in the prop blast disturbance, did not prevent it from working as it should. A better place would be under the wing at half span, but that requires some extra plumbing.
