RCU Forums - View Single Post - Another begginerish question...
Old 06-18-2008 | 03:21 PM
Missileman's Avatar
Missileman
Default RE: Another begginerish question...
A real good way to do it on that fancy computer radio is to mecahnically set your plane to the max recommended throws and set dual rate to whatever low rate you are comfortable with.
Set your high rate 5% above the low and gradually increase this as you get used to the faster rates a few degrees at a time.
