Hi
The elevators in the F16 can not be swaped from left to right due to the anhedral
Got it right this time,ah.....
The side surface of the inner chord of the elevator it is not perpendicular to the shaft, thus not allowing the change. It does not matter the colour scheme. You just CAN NOT DO IT.
What realy worries me is that I have saw that other F16 have the slot in the shaft in the downside position, while mine is in the upper position. The horn I need as to be mounted upwards with the slot in the shaft mounted upwards as well.
I am aware now that FlyEagle as understood the issue and are working to find a solution, so report your situation as well, please.
I am trying to find a photo of a suitable horn to post here.
Regds
Nuno
