RE: Another begginerish question...
Well after setting it up for max throws I am seeing something interesting.. I got roughly as much as AstroDad did out of the ailerons; almost as much out of the elevator (Rough measuring says about 5/8th inch there) and my rudder is a good quarter inch shy.. Since I do not have an incidence meter, (or whatever the tool is called that measures these things) I am eyeballing it with a ruler. Since I already know all axis worked OK before, I'm not too concerned, just thought I would mention it.
I set dual rates to %80 on the elevator and ailerons and %70 on the rudder, (My approximation of the throws I had before this adjustment). I'm going to take off tomorrow eve under low rates and once its three mistakes high set it to high rate and see where it goes.
