RE: Orderd two new WH brids! Any feedback on these?
On the 35 percent, try the front wing tube slot for balance first. I have a DA 85 and used the rear slot initially(you have to cut the tube 1 inch to fit the rear slot), and it was way to nose heavy. I change to the front slot and it is perfect. I do have a can and use 2 A123's right behind the wing tube. The plane flies extremely well!
