RE: failed radio range check-help!!
6V batteries can cause "jitters" when the battery is at peak charge. You might want to add a 6V or 5.2V voltage regulator to cap the maximum voltage going to the receiver. This will remove the jitters caused from peak voltage and still provide the fast response times and extra torque that 6V batteries give you.
