RCU Forums - View Single Post - 46LA problems
Old 06-19-2008 | 09:03 AM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: 46LA problems
Did you try closing the needle all the way, the opening 2.5 turns and adjusting from scratch? Sounds like a tuning issue, or an air leak. I would check or replace all of the fuel lines, then close the needle, open 2.5 to 3 turns, go to WOT and start leaning it out.
Trainers should climb with acceleration, even when they are nose heavy. That is by design.
