RCU Forums - View Single Post - HS-645MG Issues
Old 06-19-2008 | 09:14 AM
Brendan Lugo's Avatar
Brendan Lugo
Default RE: HS-645MG Issues
Metal gears will wear with use and will eventually have to be replaced. What you can do to tighten up the gears a bit is to pull the top case off and rotate the center gear 180* so it rides in a fresh part of the gear/teeth. Also double check the splines on the horn to make sure the teeth have not been rounded off causing some of the "slop".
