RE: 46LA problems
Look closely at the facts, your engine has been involved in a crash, it is very likely to have something broken or bended even if it is not noticeable at simple sight. I would tear down the engine and inspect every item prior rebuilding. You would like to check also the idle screw. (is not a needle valve)
