RCU Forums - View Single Post - High wing planes
Old 06-19-2008 | 01:18 PM
Nathan King's Avatar
Nathan King
Default RE: High wing planes
ORIGINAL: RCKen
ORIGINAL: Nathan King
Trainers will do quite a bit. They don't do it as precisely as possible, but they will do it.
Actually, sometimes I like to use my trainer when I am working on learning or practicing a particular manuever. The reason why is because the plane is adding NOTHING to the manuever so everything that is happening is because of my fingers on the sticks. The trainer will force you to perform a manuever by the book and do it properly. Many more aerobatic planes will allow the pilot to get sloppy and still look decent. But trust me, when you can do a manuever on a trainer and it is done properly you KNOW how to do it!!!! Try doing a single slow axial roll that is the length of your runway in a trainer and you'll see what I mean!!
Ken
I do that a lot. It really turns heads seeing an Avistar following a dead straight line using almost the whole 500' runway to perform a roll, hesitating slightly at inverted.
I get, "I didn't know an avistar can do that!" a lot. Everybody thinks you either need to pitch up before a roll or accept a slight nose down attitude after a roll. WRONG!!
If you're really feeling confident go to nsrca.org and download the sportsman pattern sequence and fly it. That will make you swallow a big piece of humble pie.
