RCU Forums - View Single Post - Angel S EVO Build Thread
Old 06-20-2008 | 03:15 AM
  #219
BaldEagel's Avatar
BaldEagel
Default RE: Angel S EVO Build Thread
ORIGINAL: mikedsilva
thinking of using a scorpion 4020-12 outrunner on 5S (5250 mah F3A pack).
http://www.flyelectric.com/Scorpion4020-12.html
would this motor be sufficient?
A 5S pack is nominally about 19volts so to get 1400watts it would need to be proped to pull about 70amps, it would be working hard, but would work, you may need to take into account the extra weight of the 5250 mah pack as well, may be a bit maginal in the vertical, I have an AXI 4130/16 in mine on 6S on 4350 mah and its as perfect as I can get on a 16x10.
Mike
