RE: Python revisited
How did your plane balance with the side carb?
With the rear carb, it didn't require any additional weight to balance, but to get the carb through the firewall, I had do cut a HUGE hole in the front of the firewall.. very close to the size of the mounting hole pattern. Between the carb and its adjusting screws, it was sizeable. Also, I had to drill a couple of holes in the bottom of the firewall box to access the adjustment screws.
I also had to build a baffle "box" around the cylinder. My temps were getting over 250 consistently. Some of this, I'm sure, was just because the motor was new, some of it was because I went with a "CS" engine, but I think a lot of it is just because the fins on 3W motors aren't as tall as the DA... they don't cool as well. After I build the box to force air through the fins, the temps dropped below 200, so now I'm happy with it.
