Morris 60 Su-Du-Khoi Help! Help!
This airplane is set up with a MVVS .77 with a stock muffler and a Zinger 14-5. It does everything I want it to.
I need help with the things I can't do.
When attempting a Harrier I'm slow, at a high angle of attack, the wing starts a rockin' and it snaps out.
Please tell me the secret. Do you reflex the ailerons? Do you cut the wingtips off? Do you push the CG farther aft. (I'm at aft CG on plans which is 6" aft of leading edge) Do you set it on the ground and jump on it ten times and find another one?
Please tell me.
Pat
