ORIGINAL: JimO
Dremel rules in model building. I have 3, two cordless and 1 cord.
Here are the photos of the wing showing how the flap servos are installed. Notice both arms exit from the same side, unlike the ailerons.
I also show how I lay out for the engine cutout in the cowl. I use the paper method for all the openings and once I have a rough cut and see how it all fits, smooth out the edges.
Dremel sanding drums in different sizes work great.
Jim
Nice looking work JimO. After you draw the box you want on the paper, do you pull it out of the cowl then lay it back on the cowling with it in place and draw the box on the cowl? If that is how, Holy Cow you made that a whole heck of a lot easier.
