RE: Won't Idle
i dont know how far you tore your motor apart but i had a problem with a no idle once and found that i put the piston in backwards. the cut out in the lower part of the piston goes towards the front. also watch the connecting rod, it has a little hole on the lower end that also goes towards the front.
