RCU Forums - View Single Post - 2wd RS4 3
Thread: 2wd RS4 3
Old 05-11-2003 | 05:00 PM
Demetree
Default 2wd RS4 3
Take out the front dog bones, and center front dog bone. Voila - 2 wheel drive.
You need to think about the fact that you will also only be able to brake using the rear wheels, so you'll be easily thrown into a spin when you hit the brakes.
I see no reason to think that going to 2 wheel drive will increase your top speed. The only advantage would be a slight reduction in drivetrain losses, which I can't imagine will result in any difference in top speed.
If you want to increase your top speed, change your gearing.
