RCU Forums - View Single Post - engine running backwards??? wut the ?
Old 06-21-2008 | 06:38 PM
Nathan King's Avatar
Nathan King
Default RE: engine running backwards??? wut the ?
ORIGINAL: gaRCfield
Well today I primed less than usual (OS 46AX). I primed until fuel ALMOST reached the carb, then 2 or 3 flips with the stick and it started in the right direction. Clearly the problem is due to excess fuel in the cylinder causing a hydrolock that we are not able to flip through, so the engine starts backwards.
N19htmare, try priming less.
Yep, that's what I said above.
