Everything went smooth!
I must've got the CG right cause I didn't need any elevator trim and a few clicks of aileron and off I went. In fact on the second flight I dialed in a little more thro for low and high rates to get the thing to come around for me.
SJ .50 with a 9X8, I didn't have the needle set just right but had one haulin A run before things got slower. I will burn a few more tanks tomorrow to get prop and needle set for max fun.
It landed like a dream too.
Also I did loose some of the trim covering on the fuse. The wing pieces held good. I went over all the edges with acetone and heat in an attempt to keep things in place.
