RCU Forums - View Single Post - PAINTING MY MAIN ROTOR BLADES - 550MM WOODIES
Old 06-21-2008 | 10:10 PM
planepounder
Default RE: PAINTING MY MAIN ROTOR BLADES - 550MM WOODIES
Man, paintin woodies!! If they are TTs shrink the cover first, most of the TT woods I have gotten, the covering is loose, I hit em with the heat gun but very CAREFULLY! I guess be sure the paint will stick to the cover well. If it starts to come loose your balance is going all to hell. If you are really wanting to punish yourself I guess you could strip the stock blades and recover them with plank covering in your favorite colors. Paintin is scary!! GOOD LUCK!
