RE: Evader down for the count
Found another quick fix. I simply took the pin that is used to turn the wheel (the pin that the wheel slides onto) and expanded it by tapping a larger diameter sewing needle into it then placed it into the CVD joint and then flared out the ends using the same method with the needle. I repeated this process on the other side as well. Gave it 3 runs and so far everything is holding up. As for the pin used for the wheel, I just made my own with a brass nail and cut it eactly the same length as the other one. I know this one wont fall out as the wheel is definitely going to hold it into place. I just need to watch it when removing that wheel. This setup should work fine until I get new spring pins.
