RE: Futaba 608FS reciever locout/failure due to heat
Throttle failsafe was set, when the reciever fails you have nothing failsafe is for when the reciever recieves no signal from the transmitter, if you were as smart as you thought you were you would already have known this and not have had to ask the question. We were able to reproduce the problem after the failure. The antennas were inside the fuse.
The range check was fine, this was done earlier in the day. He already had 1 flight on this plane early in the day when the temp wasn't as hot and when it was cloudy and all was fine.
You are getting the whole story if you choose not to believe it that is up to you.
If you could read you would know that i am not the A&P, I am just the person trying to help get the information out. I was there when it happened and helped to troubleshoot the problem.
Don't accuse someone of lying when you don't knowif they are or not it always brings out the worst in people.
