RE: Landing Gear Replacement
I am using the Dubro gear on my plane. It works and looks great. The gear at your LHS should work fine too though. Any difference you notice you will compensate for without even realizing it, especially because the height is the same. The height is the only thing that would change how your plane taxis and takes off. That can be corrected by using different size wheels, too, just in case there is a slight difference.
