RE: 100cc plug distance, Getting it closer
The 10mm plugs don't last as long but if space is critical it can be done. A little more pricey for the plugs since they aren't as widely used. The problem is obtaining some of the ignition systems with the right size caps. If you're prepared to change out the caps no biggie.
