ORIGINAL: Corwin38
Pe,
Would it be possible for me to purchase one of those reducers from you? I am having a very difficult time locating one from the LHS here.
If I DID decide to replace the cylinder head, would I need to go through the break-in procedure again? Would I need to replace the ring on the piston?
Yes, you can. These items are not available from LHS's
When the engine has run not too much, there is no need to replace the piston ring. It will set soon enough to the new cylinder.
