RCU Forums - View Single Post - gas engine reversal - is it possible ?
Old 06-22-2008 | 03:16 PM
yarom's Avatar
yarom
My Feedback: (82)
Default RE: gas engine reversal - is it possible ?
How about getting a pusher prop and running the engine in the original direction?
ORIGINAL: Ravivos
is it possible to reverse the rotation of a single cylinder two stroke gas engine with EI?
I know the first thing to do is to remount the hall sensor so it will be at the same angle but in a CCW insted of CW.
is there anything else to do or retiming the engine is enough ?
the engine is a 26cc gas engine, with EI.
i need it to spin CCW so i can use it as a pusher with an ordinary prop (mounting the prop backwards)
Thank you.
Raviv.
