RCU Forums - View Single Post - What do you think of FORMOST 150 ?
Old 06-23-2008 | 06:54 AM
  #573
RCISFUN's Avatar
RCISFUN
My Feedback: (44)
Default RE: What do you think of FORMOST 150 ?
ORIGINAL: Thud_Driver
Ah, the old who's got it trick.....
Thought the problem with the booms was they twisted and broke. I guess I missed the part about putting in a vertical spar. Is that in this thread or, if not, can you say something about it. Like did you split open the boom to install it??
Thud_Driver, I guess I didn't post any photos of the vertical spar when I did it, so here you go, once you put this in the booms are nearly indestructible, unless of course you put them through the woods!
The spar is shown in the bottom of the first photo, the second photo shows the cut out hatch I made in the bottom of the boom to slide the spar in, the spar run parallel to the LE of the fin, about 3/4" back.
I hope this helps
Rich
ID:	976723   Click image for larger version
