RCU Forums - View Single Post - gas engine reversal - is it possible ?
Old 06-23-2008 | 09:31 AM
tkg
Default RE: gas engine reversal - is it possible ?
On a 4c you need a new cam and the timing must be changed.
On a 2c pistion port just change the timing. Do it all the time, some engines even run backwards better than forward.
ORIGINAL: HornetFitter
It is never going to work . The transfer port timing (in a 2-stroke)/ valve timing (in a 4-stroke) is different when turning in reverse.
If you could redesign the engine it might be feasable, but the performance would be just plain poor.
