RE: ESC Problem/Question
You could just replace the wires but that probably will not solve your problem. The switch could be the problem but chances are your ESC is probably at fault. You should also check to make sure that the wiring connections are correct. ie. batt pos to switch pos to ESC pos. etc...best of luck.
