RCU Forums - View Single Post - recieving your new himoto (or other brands) out of the box to bashing heaven
Old 06-24-2008 | 08:22 AM
hrdcoreglf
Default RE: recieving your new himoto (or other brands) out of the box to bashing heaven
Good advice. I have one thing to add, when setting your idle do not use the trim on your transmitter. When you hit your breaks it will close the carb throat and stall the engine. Use the idle adjusment screw. When checking the opening in the carb throat you should do it with your transmitter on and at full break.
