ORIGINAL: YellowAircraft
Dang,
I gotta give you some props on this one. That Yellow F-16 was amazing on your system. Seeing is believing! Wow.
Shaun,
Thank..
It just not the fan itself doing the performance. The ducting is very important as well.
I'm getting 10 lbs static thrust install. Everything had to fine tune to max performance and effecience.
I got StarFire, F-4, A-4 and F-18 to finish.
Too many toys and no time to built.
The next plane go to finish is BVM Mig-15 with TJ100 power system.
Any airframe was fly on P-60 turbine class. TJ100 will fly it all and it performance like it too.
TJ100 is the only fan on the market that are light weight set up and power enough to perform any 12-14 lbs class turbine jets.
This fan was design base on the latest brussless motor technology and preccision tooling for accurate assembly. Not only that. The rotor are balance down to 0.029/mm @ 5k rpm.
There is serious engineering behide scence to get that kind of performance.
