ORIGINAL: soarrich
Pe
Is that an antivibration mount on the DA powered plane? If so howed it workout, and you got anymore pictures of it?
Yes it is.
Vibration mounts on gas engines are not that good in the long run, because they allow the engine more movement. This hurts the ignition lead, the hot exhaust header and the carb linkage.
Especially the carb is vibration sensitive, and the throttle valve wears out.
