RE: Whitewash
I beleive you should lock in your camo theme with a coat of Dullcoat. You can then mix up a wash of acrylic white and brush paint it over your tank. I used an electric toothbrush, but a brush would as well.
If you don't like what you see, you can spray the tank with windex, which will strip the white wash and leave you with your base camo theme.
