ORIGINAL: BrianSearles
What are the normal things to do when setting up your radio? Do most of you run negative expo on the ailerons to slow the servo's response?
Heh, on JR radios, "negative" expo makes things WORST! We use positive Expo to soften control around center.
Basically the servo is trying to move a pushrod via a circular link, in a straight line.
This means that there is the most movement around TX stick center, as the circle described by the servo arm moves the most in a linear direction as the servo is close to center.
Expo acts to even things out.
I've seen many people really overdo it with expo. IMHO over 50% causes you MORE problems, because once you are past a certain point on the stick, movement accelerates.
Try this on a rudder and you'll find that you'll be unable to keep your plane running down the centerline, as you'll always be overcontrolling.
