RCU Forums - View Single Post - DA or 3W
Thread: DA or 3W
Old 06-25-2008 | 09:49 AM
yarom's Avatar
yarom
My Feedback: (82)
Default RE: DA or 3W
Lou, you can reduce your ignition battery to a 1100mah pack and it will still be enough for over 10 flights a day (a flight consumes roughly 60mah on a DA-50R ignition). That would save you some weight in the nose...
ORIGINAL: Capt Lou
I just got my first gas engine, a DA-50 with a Pitts muffler. Put it in a Wild Hare Extra 300. It started right out of the box. I now have 50 flights on it and just completed using the fuel with break-in oil. It started up easily on all 50 flights and has run very well. After about 20 flights I had to lean the carb but that is all I have done. I power the ignition with a 2300 mah A123 battery pack and have had no problems. I highly recommend the DA.
