RCU Forums - View Single Post - PAINTING MY MAIN ROTOR BLADES - 550MM WOODIES
Thread
06-25-2008 | 06:09 PM
12
Charlie
Dec 2001
2,586
Fredericton, NB, CANADA
RE: PAINTING MY MAIN ROTOR BLADES - 550MM WOODIES
Get a bolt that is long enough to go through both the blades and sticks out about an inch on each side of the blades, you might have to put a nut on the outside of each blade if your bolt won't hold the blades tight together (your blades have to be tight together so they won't flop). Make sure the blades are strait, then balance them on the two glasses, if the tip of one blade drops down and hits the table, that is your heavy side, put your tape on the other blade until the blades sit level.
Reply
Like
Charlie
View Public Profile
Send a private message to Charlie
Find More Posts by Charlie
View iTrader Profile
