RE: PAINTING MY MAIN ROTOR BLADES - 550MM WOODIES
I still dont get it.....................haaa,, just kiddn,,i gettit now...That is pretty interesting..Glad you went into more details...I do need to invest in a good balancer..When i Fly and i see there's a problem with the blades, i'll check the tracking first and if that's good i'll spool it up and lift it 5 feet and if i see double blades i'll put tape on one side, spool it up again and adjust,,and i'll keep doin that till i get it right...Boy what a waste of time,,,,,i really need to get a balancer to avoid all this......
Thanks tho for the info....
i do have 1 more question since were on a Rollll..
i have the Raptor E550 30sz Heli..i want to put a 50size boom and belt to make it look longer and bigger looking, but have no intentions of gettn a bigger motor or gearing or putting bigger blades...,...I just want the longer boom for making it look a little bigger....Still using 550mm blades.....have any of u ever done that? Everything else will remain the same,,,all i want to change is the boom and longer belt and of course the Tail Rod. What's your feedback on this..
Reggie
