RCU Forums - View Single Post - Degrees of Thrust Question
Old 06-25-2008 | 08:42 PM
Bosch232
Default Degrees of Thrust Question
When someone says "use 2 degrees of right thrust" when mounting an engine, does that mean shim behind the right side of the mount, or behind the left side of the mount?
In my mind, shimming behind the left side achieves "right thrust".
Correct?
