RE: losis crawler
Losi Mini Rock Crawler
The 1/18 Mini Rock Crawler is a new and unique edition for the 1/18 scale sector of the hobby industry. This RTR with everything included will be a new vehicle category creator similar to what the Mini-T did for the hobby by allowing 1/10 scale enthusiasts to come indoors and compete in smaller spaces. Losi has recognized the growing popularity of the R/C rock crawling hobby and is proud to bring to the rocks the 1/18 Mini Rock Crawler. Not only is the Losi Mini Crawler the very first 1/18 scale RTR crawler in the world, but it also has the first complete RTR with everything included - just open the box and hit the rocks.
Designed from the standards of the full scale rock crawling world as well as the custom build RC platforms that have had great success, the Mini Rock Crawler is the perfect way to allow hobbyists to get involved with the excitement of R/C rock crawling with a competition ready rig.
What makes the 1/18 Mini Rock Crawler an Everything Included RTR?
Losi Radio system featuring Spektrum 2.4GHz DSM technology
7.2V 1100mAh battery pack with wall charger
Losi Mini Rock Crawler Forward and Reverse Rock Crawling Specific ESC and high torque Mini Rock Crawler Motor
The transmitter batteries are even included, just hit the rocks!
Why is the Losi Mini Crawler a ground-up crawling machine?
Twin Vertical Plate (TVP) Chassis for superior chassis strength and lightweight design
Multi-link suspension allows for extreme grip and climbing of any obstacle
Three-gear center transmission with a spool an slipper absorb shock from the full time four wheel drivetrain in action
Heavy-duty metal ring and pinion gears, solid axles, and axle shafts with a full set of ball bearings
Extra long oil filled shocks in the front and rear
Mini Rock Claws Tires mounted on heavy-duty wheels with 12mm hexes and color match inserts
High torque steering servo specifically developed for the mini rock crawler
Specifications:
Scale: 1/18th
Length: 12 in
Width: 7 in
Wheelbase: 8.5 in
Weight: 2.04 lb
Tire Size: 3.70 in
Wheel Size: 1.9 in and 12mm hex
Expected Release Date - Mid-August
