RCU Forums - View Single Post - 3W75 lack of fuel pull
Old 06-26-2008 | 05:40 PM
OTT
Default 3W75 lack of fuel pull
HELP!
I'm trying to get a new plane in the air, and I'm using a 3W75 that last flew last year. I've got everything ready to go, but when I try to test start it, it doesn't seem to be pulling fuel from the tank to the carb.
I just finished pulling & replacing all lines, hoping that I had a pinhole somewhere. After they were replaced, I tested the lines, and it seemed that everything was A-OK, but when I reattached everything, I still don't seem to be pulling gas into the carb. Shouldn't I be able to see the fuel being pulled up the fuel line into the carb? There's air in the line, approximately the last 1 1/2" or so, just before the carb, that doesn't seem to change when I spin the prop. I expected to be able to see the fuel flowing down the line and into the carb while spinning the prop.
I'm hoping to maiden this plane on Monday, but no-go until this issue is resolved.
Any help would be most welcome!
Thanks all,
Ott
