RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 06-26-2008 | 07:28 PM
  #6589
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: Barrrick
RICK HERE, and HELLO to all :
Now I will show my IGNORANCE, but I am a bit "stubborn" and want to come back on the subject. :::
I confirmed with the seller that the ADDITIONAL T-REX is on it's way in. Now, this T-REX is and EXACT REPLICA of the one that LLLOOKYJJ assembled for me and that was flown a couple of times by JER out in Cali. and twice here, by me.
EVERY item on this new TREX is the same : the JR 265s the 3400 tail servo, the 500T ring GYRO, the motor, etc etc.
I have the first TREX programmed in a model in the DX-7
I am installing a new, never used 6100e receiver.
MY QUESTION IS ::
it seems to me that I can make A COPY of the programmed TREX in the DX-7 onto another "model" and name it, maybe; TREXTWO
once that copy is made,
WOULDN'T I just have made all the work to re-program , superfluous ??????? it seems that once the system is BOUND (BINDED ??? ) THE RECEIVER WOULD JUST RECEIVE WHATEVER IS COMING OUT OF THE TRANSMITTER.....
except, OF COURSE, for all the small and necessary trims and adjustments that one would find while attempting flight. But basically, the movements (ROUGH AS THEY MAY BE ! ) on all the servos, provided they are connected correctly and equal to the first TREX, should OPERATE from the git'go, since everything is an exact duplicate...... ( ? )
if I am not getting this right, or what I say is WRONG, then I MARVEL AT MY OWN OBTUSENESS......... please please comment.
And I may add that the HBK-2 that CRASH-CRASH made for me, could be done the SAME, if it were available in the DX-7 because now there are 3 (THREE) flying HBK-2 s here, as well
RICK
YOU CAN COPY JEREMY'S PROGRAM TO MODEL #4, but then, you'll have to program in the trim and pitch curves the new heli likes. AND YES....MORE 6100E's.....you can copy for the other HBKII's, and they will have to be adjusted accordingly. SWASH SETTINGS MAY BE DIFFERENT THOUGH.....[>:]...LMAO. I played hell with the swash settings on the Ranger, but I finally got 'em. If you check the tail rotation on the Ranger HBKII...it might be different than that of your stock HBKII....I don't remember for sure.
Lights are done LMAO....
ID:	979206   Click image for larger version
